> For the complete documentation index, see [llms.txt](https://docs.pascom.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pascom.net/en/setup/endpoints/admin-phone-webui-pin.md).
# Generic SIP Endpoints
How to integrate SIP devices from non-officially supported manufactures into your PASCOM cloud phone system
{% hint style="warning" %}
Please note, the PASCOM support team is not able to provide support services for integrating non-supported endpoints. Please use our [forum](https://www.pascom.net/forum) should you require assistance with such an integration.
{% endhint %}
## Restrictions
Non supported phones can not be automatically configured nor be configured with the PASCOM menu on the endpoint.
Remote CTI control via the PASCOM App is only possible in a restricted form.
### Endpoint Requirements
In order for a SIP device to operate with the PASCOM server, the following functions are necessary:
* **SIP via TCP/TLS** (encrypted signaling)
* **SRTP** (encrypted voice data)
* **Outbound Proxy** (send data via the Session Border Controller)
## Preparation and login data
{% hint style="success" %}
Unfortunately, many vendors use different names for effectively the same settings. This means you may need to experiment a bit. The following table shows the common terms used.
{% endhint %}
| Setting                      | Example value         | Description                               |
| Registrar, SIP-Server        | **pascom**            | Name of the phone system                  |
| Proxy, Outbound-Proxy        | **pascom.cloud**      | DNS name or Server IP address             |
| SIP-Port                     | **TCP 5061**          | TLS SIP Port                              |
| Username, Identity, Authuser | **my-telephone-name** | Device login name                         |
| Password                     | **\***                | Device password, not the user's password! |
### SIP TLS and SRTP
Read the SIP endpoint handbook regarding how to activate SIP TLS and SRTP. This could involve multiple setting configs.
## Create a new Basic Configuration Template
The next step is to build a new basic configuration for the SIP device. To do this, go to the PASCOM WEB GUI on **Devices** > **Basic configuration**
With PASCOM version 19.03 there is a new basic configuration **Empty Generic Profile**
{% endhint %}
Duplicate the basic configuration **Empty Generic Profile** and give it a name e.g. My Yealink Devices. Select the new basic configuration and click on **Edit** > **Configuration**.
**You have to adapt the following code part to your device-parameters. The listed variables are used to automatically fill in the correct login/server data.**
{{!-- This is a example template -}}
{{!-- Please clone and overwrite this Profile -}}
{{!-- use regular expression to match a request uri to a template snipped -}}
{{!-- a empty template output (i.e. no if_regex matched) will return a 404 response-}}
{{!-- this "if" block catches request directly to the provisioning url (/) -}}
{{#if_regex "/provisioning/ee[0-9a-f]+/?$" http_path}}
You requested the example generic template.
Please try two other routes:
- append /example.cfg for a example provisioning file
- append /info to the url to see a list of all variables.
{{/if_regex}}
{{!-- requests ending with .cfg (e.g. /y02384.cfg) will be handled here -}}
{{#if_regex "\.cfg$" http_path}}
sip username = {{{013pee_username}}}
sip password = {{{013pee_password}}}
sip host = {{{httpip}}}:5061;transport=tls
sip domain = {{{cs_domain}}}
{{/if_regex}}
{{!-- here, each request ending with /info will be answered -}}
{{#if_regex "/info$" http_path}}
Variables:
{{#each this}}
{{@key}} => {{this}}
{{/each}}
url parameters:
{{#each http_params}}
{{/each}}
{{/if_regex}}
Save the basic configuration.
## Apply Jobs
After saving your changes, an entry will appear in the job box (top centre of the window). Start the job by clicking apply or the `green tick`.
## Create/Add the SIP Device
Insert under **Devices** > **Device list** a new device of type **IP-Telefon: Hersteller beliebig oder Softphone**. Now select the **new basic configuration** you created earlier (My Yealink Devices).
Under the tab **Assign** you give the SIP device an user. Finally save!
## Provisioning on the SIP Device
Check the IP Device in the device list and go to **Action** > **Provisioning URL** where you can copy the **provisioning URL** to the clipboard.
Each SIP device has its own web interface. How to get there, please refer to the instructions of the respective manufacturer. The **Provisioning URL** usually has to be set in the **Servicing** settings of the device at the server URL. After applying the changes and a **restart / reboot** of the device, the settings are automatically transferred to the device via the provisioning URL.
## Test Call
On the SIP endpoint, please dial **\*100**. This should call the PASCOM Voicemail box and you should here the mailbox prompts.
# Agent Instructions
GET https://docs.pascom.net/en/setup/endpoints/admin-phone-webui-pin.md?ask=<question>&goal=<user_goal>
