> For the complete documentation index, see [llms.txt](https://docs.pascom.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pascom.net/en/reference/howto/wrong-scaling-of-pascom-client.md).
# Workaround for wrong scaling of the PASCOM App
With this workaround you can fix a wrong scaling of the PASCOM App on Windows.
In special cases, it can happen that the scaling of the PASCOM App does not look correct. This only affects Windows users and only in certain monitor/resolution combinations. This workaround should help to improve the scaling of the PASCOM App.
### PASCOM App scaling not correct, what can be done?
If the control elements of the PASCOM App appear either too small or too large, adjusting the HiDPI scaling of Windows can be helpful. Instead of scaling the application itself, this can be done via Windows.
Close your PASCOM App and then right-click on the shortcut to the PASCOM App and select the menu item **"Properties"**. There, switch to the **"Compatibility"** tab. Depending on the Windows version, the settings for high DPI (HiDPI) are now available here.
<figure><img src="https://2713225-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FVIw0BpSv358R2Pr2HflD%2Fuploads%2Fgit-blob-f793f86848977b44df84f563268cf40652f52f54%2Foverride-hidpi.de.jpg?alt=media" alt="Override High DPI Settings" width="50%"><figcaption></figcaption></figure>
<figure><img src="https://2713225-files.gitbook.io/~/files/v0/b/gitbook-x-prod.appspot.com/o/spaces%2FVIw0BpSv358R2Pr2HflD%2Fuploads%2Fgit-blob-f5f90dcd30e50d37e323af8aecc41a267da5ce5c%2Fdeactivate-hidpi.de.jpg?alt=media" alt="Deactivate High DPI Value" width="50%"><figcaption></figcaption></figure>
By adjusting the HiDPI scaling, you can achieve an optimal size of the PASCOM App controls to ensure a pleasant and legible user experience. Please note that changing the HiDPI scaling can lead to a blurred font display.
# Agent Instructions
GET https://docs.pascom.net/en/reference/howto/wrong-scaling-of-pascom-client.md?ask=<question>&goal=<user_goal>
