> For the complete documentation index, see [llms.txt](https://docs.pascom.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pascom.net/en/reference/howto/ubuntu-pipewire-audio.md).
# Using PipeWire Audio on Ubuntu Linux
With this guide, you will learn how to improve your audio quality with PipeWire on Ubuntu Linux systems.
## Overview
By default, the PASCOM App on Ubuntu Linux distributions uses the default PulseAudio daemon. Here, it may happen that your audio quality sounds "tinny" or "robotic". To fix this problem, you can use the PipeWire Audio Daemon, which provides a solid workaround.
{% hint style="warning" %}
The PASCOM App was tested with PipeWire only on Ubuntu distributions.
{% endhint %}
## Install PipeWire
Run the following commands in your terminal environment to install PipeWire. This will also make PipeWire the default audio daemon for the logged in user.
#### Add PipeWire repository
sudo add-apt-repository ppa:pipewire-debian/pipewire-upstream
sudo apt update
#### Install PipeWire
sudo apt install pipewire pipewire-pulse
sudo apt install pipewire-audio-client-libraries
sudo apt install gstreamer1.0-pipewire libspa-0.2-bluetooth libspa-0.2-jack
#### Set PipeWire as default audio daemon
systemctl --user stop pulseaudio.service pulseaudio.socket
systemctl --user disable pulseaudio.service pulseaudio.socket
systemctl --user mask pulseaudio.service pulseaudio.socket
systemctl --user enable pipewire.socket pipewire-pulse.socket
systemctl --user start pipewire.socket pipewire-pulse.socket
#### Reebot System
To apply the changes in Ubuntu, you must reboot.
sudo reboot
## Use PipeWire
After installing and setting up PipeWire, the audio daemon is automatically used by the PASCOM App.
1. At this point, check your audio device settings again, which may have changed due to the change of the audio daemon.
# Agent Instructions
GET https://docs.pascom.net/en/reference/howto/ubuntu-pipewire-audio.md?ask=<question>&goal=<user_goal>
