> For the complete documentation index, see [llms.txt](https://docs.pascom.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pascom.net/en/reference/howto/dialplan-loop.md).
# Remove Dialplan Loops
How to identify, avoid and fix Dialplan Loops
## Overview
A dialplan loop exits when during a call, an extension is traversed 30 times. This happens e.g. through call diversions and drops that are set incorrectly and thus end in a loop.
## Warning Notification
In the job box, a warning notification will appear as below:
CRITICAL: A dialplan loop was detected
## Remove Warning Notification
The PASCOM cloud system automatically clears this warning message the next time you save changes via **"Apply telephony configuration"**.
## Avoid Dialplan Loop
If this warning message occurs, check your call diversions and drops within your call flow. At some point, a loop will form here. Modify your call flow so that loops are avoided.
# Agent Instructions
GET https://docs.pascom.net/en/reference/howto/dialplan-loop.md?ask=<question>&goal=<user_goal>
