> For the complete documentation index, see [llms.txt](https://docs.pascom.net/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://docs.pascom.net/en/reference/howto/color-blindness.md).
# Support for colour blindness and colour vision deficiency
Learn how to modify the PASCOM App as a colour blind user or a user with sight difficulties.
## Overview
Working with software with **colour blindness** can be challenging for many people. Colour blindness means that a person has problems distinguishing certain colours, which can make it difficult to navigate and use software. The PASCOM App has a high contrast user interface that can be used in 2 different colour schemes, but both have very colourful navigation. However, there are some options that can help people with colour blindness to work more effectively with our software.
## Colour blindness and colour vision deficiency in detail
Colour blindness is generally divided into different visual impairments. Here there is **protanopia** (red/green visual impairment), **deuteranopia** (green/red visual impairment) and **tritanopia** (blue/yellow visual impairment). Here you can generally work with different colour filters to achieve a better contrast so that differences are easier to see.
## Helping with colour blindness
It all depends on the right settings. As just mentioned, you can work with various colour filters to remedy the situation. There are, for example, **high-contrast modes** to better distinguish colours, or **colour corrections** that can be specifically adapted to visual impairments.
{% hint style="info" %}
The PASCOM App does not have a mode or settings for colour blindness.
{% endhint %}
The PASCOM App does not have its own mode or settings for colour blindness, so you must use the **operating system** settings. In the table below you will find instructions on how to optimise your **operating system** for **colour blindness**.
| Operating System | Tutorial        |
| Windows          | [HowTo Article from Microsoft](https://support.microsoft.com/en-us/windows/use-color-filters-in-windows-43893e44-b8b3-2e27-1a29-b0c15ef0e5ce) |
| MacOS            | [HowTo Article from Apple](https://support.apple.com/en-gb/guide/mac-help/mchl11ddd4b3/mac)                                                   |
| iOS              | [HowTo Article from Apple](https://support.apple.com/en-us/HT207025)        |
| Android          | [HowTo Article from Google](https://support.google.com/accessibility/android/answer/11183305?hl=de#zippy=)                                    |
| Linux            | No standard settings availables        |
# Agent Instructions
GET https://docs.pascom.net/en/reference/howto/color-blindness.md?ask=<question>&goal=<user_goal>
